Ac max low and high psi at 35c?
What is the max good AC low pressure and high pressure psi at 30 degrees Celsius?
should i rev the engines or on idle enough?
rx400h 2008
I Should not care about grams and cans, look at high and low pressures psi right?
engine speed should be at 1,500 rpm (not that it should really matter as the engine doesn't run the AC).
Low pressure side:
0.15 to 0.25 MPa (1.5 to 2.5 kgf/cm2, 21.3 to 35.5 psi)
High pressure side:
1.37 to 1.57 MPa (14 to 16 kgf/cm2, 199.1 to 227.5 psi)
Low pressure side:
High pressure side:
Are you sure at 30c low pressure is only 35.5 psi?
Too low?
Can you link me with a pdf chart please for rx400h?
It looks like the red unit is pressurised to about 140psi.Should you really be playing with something you don't understand?
Read the instructions,before you injure someone,or even yourself.
  • Confused 1
Are these gauges oxy / acetylene on a welding set?  If they are, and you have no experience on using them,  please read all the relevant safety instructions on how to use/ adjust pressure. Extremely dangerous kit if you have no experience.  NB. 1 bar is 14.7 Pounds per square inch. Please be careful.
2 minutes ago, cdmaskell said:
Are these gauges oxy / acetylene on a welding set?  …
The OP has posted in other threads regarding an A/C system, but agree about the need to be careful.
Read the instructions,before you injure someone,or even yourself.140
10 bar is 140 psi
Good psi is 250 psi which is 17 bar
What is the problem?
I believe my compressor is dead
Have you actually read the OBD codes to see if anything is flagged up?
Nope, just got the cable, gotta install software somehow...
But good idea, will do that
10 bar is 140 psi
