is250c rear shock absorber
Having trouble with oil leaking from what i assume is the ORIGINAL Tokico rear shock absorber. Struggling to find resonably priced replacement but also would i be advised to replace both with the likelyhood the other will shortly follow suit. Seems gas filled is what most shock absorbers are now but can they be fully refurbished back to original use/condition? Thanks in advance.
Gas filled shocks also have fluid in them. Shock absorbers have had gas over oil for many, many  years now. Shock absorbers are not generally made to be repaired or refurbished.
Hello Andrew. Just buy standard ones from Lexus Direct. There's aren't many none standard available for your car. £350 each is a fair amount to pay. Just consider how long the Original ones on your car have lasted. Lexus/Toyota spent Millions on research. Just stick with originals.
One of my rear ones has started misting/leaking so have ordered 2 rear ones through Daniel at Lexus Direct
  • 4 weeks later...
