Skip to content
View in the app
A better way to browse. Learn more.
Lexus Owners Club
A full-screen app on your home screen with push notifications, badges and more.
To install this app on iOS and iPadOS
  1. Tap the Share icon in Safari
  2. Scroll the menu and tap Add to Home Screen.
  3. Tap Add in the top-right corner.
To install this app on Android
  1. Tap the 3-dot menu (⋮) in the top-right corner of the browser.
  2. Tap Add to Home screen or Install app.
  3. Confirm by tapping Install.
Little update from b4u2
Featured Replies
  • Author
Does anyone know if it possible to adjust the windscreen washer squirter as right one is a wide shower and left is more narrow?
In my old car (honda) it was a metal hole that could be adjusted with a pin but the rx400h seems different and don't want to damage anything.
  • Replies 417
  • Views 30.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I wonder when this thread may be available in paperback ?
  • Just a few random thoughts:   I’m glad your Hybrid Check was all fine.   Is your AC working as you would like now?   I recall you bought the car from a dealer? Whilst some dis
  • Sundance
    Sundance
Posted Images
4 minutes ago, b4u2 said:
oh well your scaring me now so how do i let down air and deflate to 36?
Remove the dust cap on the valve and depress the pin in the centre to let air out, be careful it comes out in a rush! Do you have a tyre pressure gauge?
  • Author
@NemesisUK I have just let out air from all of them and made sure they are all at 36psi
If you get yourself a portable digital pump, you’re find you can preset the required tyre pressure and the pump will inflate or deflate to the preset pressure.
And of course you do this with cold tyres!
  • Author
I have 2 pumps and yes the one i just used is digital, thank you @LenT
  • Author
On 5/7/2025 at 10:30 PM, b4u2 said:
I called up Lex-Tek Autos in Sheffield for a quote on a service and was shocked at the prices they came back with.
Full service including vat is £515 and medium service including vat is £275
Almost as expensive as going straight to a main dealer
Main dealer is  RX   £400/£760
My car is 17.5 years old and to me it doesn't make sense to pay such expensive costs just for a service.
On the flip side/other hand this car has been serviced yearly up until now by Lexus Guildford with a full stamped book so i would love to keep that service history up but can't afford it......
I'm really not sure what to do but service is due NOW
I was thinking if another main dealer NOT lexus would offer a significantly cheaper service perhaps it's a good idea doing that because at least that way it will be of high standard not just any cheap backstreet garage that aren't doing the same standard and level. Thoughts?
15 hours ago, LenT said:
You may find it’s a data update, but not a firmware update.  So even if it loads, it won’t do anything to improve what is essentially a very poor system.
Considering that Lexus went to Mark Levinson to get a decent audio system, it’s a mystery to me why they didn’t get the likes of, say, Garmin to supply a decent satnav!
Oh it loads just fine. I just couldn't stand having something on the car that needed updating even though I'd never use it :laughing:
Why do you keep referring to Lex-Tek as a main dealer?
  • Author
I don't, they are a lexus specialist that's why.
I know how you feel, Richard.
it seems perverse to have a potentially useful facility available and let it remain inactive.  A couple or more years ago I noticed one supplier offering usb stick upgrades for my car, despite Lexus having discontinued them years earlier.
I emailed them for more information - although I would in fact always be using my Garmin system - but never received a reply.  I lost interest at that point!
Think yourself lucky - full service for the isf is £890. Plus almost £800 road tax, plus £50 MOT, plus insurance and all the rest.......   Getting a bit pricey, but still keeping it.🤪
  • Author
OMG!!!!!!!!!!!!!
  • Author
I am unable to remove this screw as it seemed to have lost it's thread and therefore the screwdriver is not holding?  Any advice on now to get it out?
Put a rubber band on top of the screw and try to unscrew it then - you are using a 'jewellers-type' screwdriver aren't you?
That's definitely worth a try but to be honest it looks a bit too bad for that and you may have to drill it out.
  • Author
1 minute ago, NemesisUK said:
Super glue the screwdriver to the screw head?
Lol peter you must be joking 🤣 😂
  • Author
Yes I am, that's correct Herbs.
No, it's saved me a couple of times when the screw head has been wrecked ...
  • Author
Not sure how that works.......
  • Author
Hybrid health check passed! 🙂
  • Author
Does the rx400h have heated mirrors and if yes then how does one switch it on?
If it's this one then only the left mirror heats up not my side(drivers) How do i fix this as don't want to damage anything?
Also noticed the electrics only move up and down, not side to side?
WhatsAppImage2025-05-13at14_27.25_e4f189b3.thumb.jpg.144f0a7cc0559312799a92641a95d325.jpg
Yes it has heated mirrors - the mirror symbol on the switch confirms it. If it isn't heating then I first suspect someone replaced the glass with a cheap glass that doesn't have a heating element (and non dimming too). You would need to remove the glass to see if there is wiring going to it, and if there is then measure the voltage when switched on.
  • Author
20250513_172503.thumb.jpg.97e8eed0790d74c2c3e2a59b1039e8a4.jpg20250513_172506.thumb.jpg.c55ea2c418f3243433782440597e241d.jpg20250513_172514.thumb.jpg.1a9048442ed6d526536931a30c070ddd.jpg20250513_172535.thumb.jpg.1489976602347abb300616d0597c508f.jpg20250513_172648.thumb.jpg.d5e0c2b75ea8912ef6a8e69eba74941c.jpg
  • Author
There's something not plugged in but can't find where it belongs?
Please see above photos and advise what to do
Note: Your post will require moderator approval before it will be visible.
Join The Independent Lexus Owners' Club
Our community has been built by enthusiasts, for enthusiasts, and proudly run by Lexus owners' for over 25 years. As an independentnon-official club, everything you’ll find here, advice, support, and opinions, comes directly from members with genuine Lexus ownership experience. By being a member you can gain access to active community forums, videos, news, events and more...
JOIN OUR COMMUNITY NOW!
LexusOwnersClub.co.uk (“Lexus Owners’ Club United Kingdom”) is an independent, third-party enthusiast forum created for owners and fans of Lexus vehicles. We are not affiliated with, endorsed by, or in any way officially connected to Lexus USA, Lexus Canada, Lexus UK, Toyota Motor Corporation, or any of their subsidiaries, affiliates, or authorised dealers.
All content, discussions, and materials posted on this website are generated by users of the forum and represent the opinions and experiences of individual contributors. Such content is not reviewed, approved, or endorsed by Lexus Owners Club, ACI LTD, Lexus UK, Lexus USA, Lexus Canada, Toyota Motor Corporation, or any related entity.
LexusOwnersClub.co.uk makes no warranties regarding the accuracy, reliability, or completeness of any user-submitted information.
Any reference to Lexus trademarks, logos, or brand names is used solely for identification and informational purposes. This site does not claim any ownership of Lexus intellectual property.
For official information about Lexus products, services, and corporate communications, please visit the official Lexus website relevant to your region.
Background Picker
Customize Layout
Account
Navigation
Search
Search
Configure browser push notifications
Chrome (Android)
  1. Tap the lock icon next to the address bar.
  2. Tap Permissions → Notifications.
  3. Adjust your preference.
Chrome (Desktop)
  1. Click the padlock icon in the address bar.
  2. Select Site settings.
  3. Find Notifications and adjust your preference.
