Oil
d3fy
Yes GTX Magnatec is really the minimum quality (semi-synthetic) you should use given the 10k mile drain interval.
If you wanted to stick with Castrol and want fully synth. then look at Castrol RS although that comes in 0W-40 which isn't specified in the owners manual.
Ive always used Mobil 1, i used to use it in my old fiat diesel and even in that i only had to change the oil once a year, it always passed the emissions test even though it was 10 years old. When my lex is due for its service im gony get Mobil 1 again, its fully synthetic too :)
