Trunk Light
If it doesn't work, check the connections, also does the car doors trigger the light like normal?
Yes it does when I open any door, but not when the trunk is open, I assume the light maybe burned out cause I checked the connections and is all fine. I even tried to take off the trunk key assembly and re install it and still doesn`t show that is open while it is. everything else works but the light.
