Power Steering Stiff
sorted vti
i got a bit of an issue with my power steering.
it makes a bit of a sqeeling noise when u turn the steering on the spot. and its quite stiff aswell
always stiff when u first turn the car on.
checked the fluid and its fine!!
im stumped
pray it aint the valve just cost me £240
sounds like u if making sqeeling noise hopefully its just a loose belt get it tightened :)
mine too was doing the same, my car was serviced last week and i asked them to check it out. im not sure what they did but all is well now. i assume they tightend the belt, i forgot to ask when i picked the car up
fingers crossed it isnt that then.
yeah as i say its fine when ur driving, just when ur staitionary.
is it easy to tighten the belts? havent investigated fully of where all the bits are yet
Pretty straight forward to tighten, A bolt round the back needs loosening and I think one at at the front as well.
I thought I had a photo - but must be on home pc
(oddly I had to loosen mine to as loose as poss without slipping as it made a grinding noise when tight - as a result of a crash)
oh nice one. thats very kind of ya mate. yeah might have to pop up one lunch time if im about (normally out on the road, fitting signs somewhere) also want to check this in-car pc u was talking about. reckon i need to get one fitted to my car when i can afford it.
I got a squeaky belt what did you use to pull the belt tight eg a bar or just your hands :duh:
  • 2 months later...
