Cd Player/stero Issues
First ever post:
I have recently brought a IS200 however upon driving it home i had a few issues when attempting to use the CD player (Has the slot at the top of the stereo). There maybe a easy fix or not. Or i may even be a total fool and not know what im doing.. (Probably the later.)
1) When i try to insert a CD into the slot it wont let me insert one.
2) I press "LOAD" it seems to try to load disc 1 but as far as i am aware there is no disc in there.
3) Pressing "EJECT" seems to do nothing.
I would be much appreciated if anyone has any advice on my issues as its kinda annoying not being able to play CD's. The changer mechanism seems ok as it makes all the right noises when i press load and there is no ERR3 messages being displayed.
Many Thanks.
Oli
remove the fuse wait a few seconds then put it in again - see what happens as the radio should go thru and see if any discs are loaded.
fuse is in drivers footwell i seem to remember.
Thanks for that i will give it blast when i get home. If that doesnt sort it i will take the stereo out and see if there are any stuck discs in it. Is it easy to remove, any one got a brief guide how to remove them as i dont want to break it or anything. :)
First ever post:
Many Thanks.
Oli
hi when you press load the light on the front will turn green for you to insert the disc ( you have to wait for it to turn green and display LOAD ) you then put the cd in and the player should take the cd in, if there is a disk in the first slot of the multichanger it would find the next available slot out of the six and display this on the front of the unit unless all six are full up?
Oli
Thanks for all the advice. I have tried the above and when i press the LOAD button it says "Load Disc 1" however the lights by the CD opening do not change they just stay orange. Does this probably mean there is a CD stuck in it??
First ever post:
Many Thanks.
Oli
could well be a stuck disc mate...try and do what was said by the other member and remove the fuse and then put it back in..
First ever post:
Many Thanks.
Oli
I will give that a blast, does it lose the code for the radio if i remove the fuse??
older radios only have orange lights, newer ones have both i believe...... have u actually tried to put a cd in????
radios do not have a code so dont worry about that.
Mines has only orange lights so it seems on the stereo, its a 2000 X Reg Sport. I also cant seem to see a fuse box on the drivers side ive looked at the manual and it shows the only fuse box as being under the bonnet?? Ive tried to yes and it wont let me. Ive pressed load and tried to insert a disc and it wont let me!
  • 2 months later...
Was there any resolve for this issue? When I bought my car I found I had the exact same problem. I've tried everything I can think of, i've even had the cd player in bits and put it all back together but ...... suprisingly it didnt help. Past the day though lol. I assume its just knackered. I would have thought it would have given an error code though! Im strongly thinking about just changing for an aftermarket if it really is broke.
Afraid not, i took the cd player out and there were 7 discs crammed into the changer, I managed to remove 4 however there are 3 still stuck in there. Im planning on taking it out again and removing the last 3. However you seem to have to remove all power then the changer goes through a reset process reads all disks and you can then remove them 1 by 1.
Seems the only resolution is to replace the OEM with a aftermarket one.
  • 2 months later...
Hi all - virgin poster here :D
I hav just bought a 2002 SE and have the same problem - no error messages / only orange CD lights blinking etc...
I'll give the 'take fuse out' a go n see what happens !
Hay guys
having same problem
seems to be a common fault with the standard cd player :tsktsk: mines seems to be acting up , i have managed to eject all discs and i am only able to re load one disc , if i try to load more it makes the lovley grinding noise and then the ERROR3 code appears
before i ejected all the disc ( 6 of them ) there was the grinding noise when skipping to the next disc - as if they werent catching the tray , but i found a good hard bangs to the side of help the cd play .
now nothing except the one disc
please help
you can actually only listen to one CD at a time :whistling:
There is only 3 solutions
1. send your cd player away to someone who will fix it (but it may go wrong again)
2. buy a new cd player from Lexus (:o £££ :o)
3. replace the Head Unit with an aftermarket one
theres always one :lol: i know you can only listen to one at a time , but if i want to to change the cd .......................well i suppose im just being lazy and dont want to eject the only cd to manualy replace it :(
looks like i may be getting an aftre market one then :whistling:
I tried taking the fuse in the kick panel (says Radio-2) out but still the same. is there another fuse some where else?? (Radio-1)???
I dont trust myself taking the whole stereo out and dismantling it :crying:
I have a felt pad at the top, is this glued down? (Soz 4 being thick!)
Does any1 know of an independant Lexus garage around Oldbury / Tipton area?
SORTED!
Great tutorial to remove stereo. Did mine over the weekend - three Cd stuck inside.
Opened the unit and removed them, now it works fine!
Saved me some money - just need to get my wheels done now. :blush:
Again thanks :D :D
  • 2 years later...
