Is200 Radio?
Hate to say it mate but that radio is a bit umm bust ERR-3 is quite common on the models
if you do a search there are ons of posts regarding that dreded code, best thing put and Aftermarket one in and get the by pass cable you wont look back
Were do i purchase the surround to replace the radio?? sorry for ball busting
Sorry don't understand, the surround? If you mean the fascia, ebay's probably the best bet (or ask your local car audio fitters) If you mean the bypass lead, again eBay.
See Wozza's guide for more info:-
http://www.lexusownersclub.co.uk/forum/ind...c=46907&hl=
Oh...and good luck!
Err-3 DOH !! Complain like fury to the seller !!!!
All the info regarding the replacement of the Lexus head unit is covered in my IS200 ICE thread.
This also covers the different options available with regards to the Facia adaptors. Any comments welcome :D
Most people use the Autoleads Facia FP-25-00 for single din Head Units. The same unit can also be
assembled in a Double Din configuration. I further modified the facia so it matches the dash perfectly.
They have a rough finish out of the box, hence the modification.
(see here for more info, walkthru & pics ) Again any comments welcome :D
There is also a Toyota Part, but this needs the desired hole cutting out, and you may loose
TRC or Heated Seat buttons depending on your model.
If you want a guide to removing the CD Player, please send me a PM with your email address.
I have a word document that covers it completely with pictures and tips/hints etc.
regards
Wozza
if it helps i might have a headunit from my 2002 sport up for grabs this one has no error code as of yet i hardly used the cd function any way
If it's anything other than the 13902 model then I might be interested if it's cheap enough. I bought a Grom iPod interface and installed it without owning an iPod yet and THEN found out that it won't work with that model! :angry:
