As per the title, discovered at the MOT today that the sidelights were dead. I've replaced them now but I thought it curious that the car didn't tell me about this.
Is there a fuse I can investigate? Conveniently, the page in the manual that lists the fuses has been torn out.
Hope you have read the other posts from learned Members about LED bulbs and maybe it's best not to bugger about changing from OEM bulbs !!!!
Something to do with resistance levels and sodding - up the circuits.
Both my front sidelights failed recently too. I replaced them with some LED's --they've been no problem so far, though they havn't been in that long, admittedly. I don't think they are the cheap Chinese ones. Fitting them is a bit of a faff but the job only takes about 5 minutes each side once you know the foibles of removing the headlamp and indicator lenses.
