Wind Noise
RedLexus
I'm getting wind noise in the drivers door , it used be only at about 80mph , now I after a couple of weeks its audible at 60 . I wipe the door rubbers with trim shine regularly , and I can't see how to adjust in the door latch . The car is an undamaged '02. Suggestions , anyone ? :unsure:
Hi
I had this its the rubber worn or badly fitted (door might have dropped). lexus brighton replaced after resolving first by wiping with a silicon mixture... seemed to work for months, no idea what it was but it worked, ask no questions, seemed to a common fault?
Door adjustments are behind front wing, body shop visit.
Hope this helps
