Hi all,
I have started this topic trying to help anyone who has a problem with the hybrid Battery on a lexus gs450h . About a month ago i was stuck in traffic and the check hybrid system came up on but the car was still drivable and only a bit more lazy on acceleration . After i arrived at home i plugged the scanner and it came with the error code P0A7F - Hybrid Battery Pack Deterioration and check VSC message. I have cleared the code and looked at the Battery modules voltage but they were all looking fine so i assumed it was just a one off. The car was fine but after one week same thing happened again and meanwhile the car was feeling a bit different anyway, the only difference this time it was the error code P0A80 - Replace Hybrid Battery Pack. Unfortunately my car has done 124k miles and also the last service was done with an independent specialist so i had no warranty. I kept researched on-line and i found someone in Northampton that recondition and repair hybrid batteries for Honda & Toyota. Meanwhile i have also discussed with someone from London and he said he will fix my car in 4 hours but he never done one before. I decided to use the guy in Northampton who's name is Richard, a very nice guy and helpful. He said he will need the car between 5 and 7 days and will give 10k miles warranty or one year , whatever comes first . Dropped the car on on Tuesday because it was still drivable just without abs, vsc and cruise control and picked it up this Wednesday . The car feels great now and also the fuels consumption is with a few mpg's better. The guy also has a website but i am not sure if i am allowed to post it here so i will leave his phone number is someone is interested.
Richard Hybrid Battery solutions - 01604404644 .
No problem with posting the website. Do you know what work was done - replaced a cell, a recalibration or a dismantle and clean of all the connectors?
The website is the same like his company name, just type in on google hybrid Battery solution UK. As far as I know he definitely replaced a cell and reconditioned all the modules plus the 12v Battery. I suppose he also cleaned the connectors but I am not sure.
This is a great post Adrian and will hopefully be useful to us all when the time eventually comes.
Hoe did you check the Battery module voltages? Was this with diagnostic tool or just with a volt meter?
Also, were there any symptoms before failure?
And, how much did the guy charge you to repair it?
Thanks.
Giles.
I have checked the voltage with the diagnostic tool and the lowest one was 16.61V and highest 16.76V. To check the module with a multimeter you have to take the whole Battery pack out and open it.
About the symptoms, no it wasn't anything before, only after the first error code the car was not holding the charge as much as before and i could not feel the power as i used to know it.
I have paid £800 for the repair and it took 1 week to be done.
Thanks or the info, but could you tell me which diagnostic tool you bought to be able to read the individual Battery voltages?
I bought a Tachyon tool which is supposed to read the Battery voltages, but it doesn't seem to on my car.
Thanks.
Hi there,
The Diagnostic tool I use is Toyota Techstream chaps - its definitely the best & allows me to capture live data including cell unit voltages & internal resistances.
You need a laptop that is running the Windows XP 32 bit O/S then if you look on ebay you need to buy the mini VCI & software - if you are PC Savvy you wont have any problems getting it all to work,
Yes I replaced a cell module & rebalanced & reconditioned the entire pack together with my special system i designed & built myself.
I am happy to help
Richard
Toyota Techstream is really the only thing that can be used. Toyota don't release their proprietary diagnostics information so any other tool has just used a reverse engineering method to try and work correctly.
The downside is having to pay a four figure sum to legally obtain the right to use Techstream. Our forum T&Cs don't allow the discussion of obtaining software illegally.
I know it's a different car, but I've seen a very similar example with a prius. The terminals and bus bars develop a small amount of corrosion over time, which can easily be cleaned off once disassembled, in the same way that you can clean corrosion off a normal 12V Battery. Because there are a lot of contact points and a lot of current, the voltage drop (and power dissipated) can be enough to cause fault codes with what appears to be very little visually. With the corrosion removed, the example I saw was back to full health, but in the case of a faulty cell it would also be possilbe to replace that (rather than the whole assembly).
Here's the album of the work, showing step by step what can go on inside the Battery, how to test cells and how to fix corrosion induced problems:
http://imgur.com/gallery/j8Bcp/
It's rare in my experience that corrosion actually causes major problems although of course it can happen' toyota/lexus placed absorbent material under terminals in an effort to absorb leaking electrolyte which is a powerful hydroxide which in turn causes corrosion as its nasty stuff.
Although corrosion can be a contributor it is much more common to see failed cell modules.
The Lexus Hybrids draw a fair bit more power from the Battery packs than Toyota's do which accounts for the shorter warranty period.
It is rather strange that warranties in both cases seem to run out more or less exactly at the time most packs are likely to start failing?
The power/warranty statements aren't entirely true. Some of the Lexus models draw more power, although the Toyota badged variants of the same vehicle in other countries draw the same, but the CT for example is just an Auris/Prius in terms of hybrid drivetrain.
The warranty period has nothing to do with power draw, it is just a marketing thing. Toyota can get away with just providing a lower warranty on Lexus vehicles in the UK compared to Toyota vehicles. In the US the Lexus hybrid system carries an 8 year warranty, the same system that is on the UK vehicles, and the same as Toyota.
No that isn't correct. I believe the Battery pack on the GS is 288 volts. The inverter boosts that to around 650 volts DC and the converter creates a 3 phase AC voltage with supplies the motor.
There are two other DC-DC converters, one 288v to 12v for normal car electric functions and recharging the aux Battery, and the other 288v to 46v for the power steering.
It is actually 650ish Volts independently tested, the 6KV I read was a typo, although if effective insulation could be developed KVs actually makes quite a bit of sense with the appropriate safeguards of course
I have just had my GS450H Battery refurbished by Richard. The 145 mile drive home from Northampton was a real pleasure and the cost (including 290 miles of fuel and a return train ticket was still less than half the cost of a replacement by Lexus. Richard is a very pleasant bloke as well.
Highly recommended.
Hi I've just used Richard and recommend him highly;  in my case there wasn't a problem with the hybrid Battery but he was incredibly helpful and I'll be sure to use him if / when my GS450H Battery does need to be refurbished.
G'faw, you just 'used' Richard...for what?!
I was just about to ask the same question!
Richard PM'd last night and he's okay :w00t:
Rupert just went over for a diagnostic.
  • Similar Content
    • By Shyamal IS300H-FSPORT
      Hi all,
      I have recently bought a Lexus IS300h F port and I was told to get a tracker fitted by one of my colleages. I have bought the tracker that was suggested to me but I have no idea where or how to fit it.
      The instruction manual says to attach it to a 12-36V charger (I'm assuming the 12V Battery in the boot). I have never done anything of this sort before so I just wanted to ask
      a) is it safe for me to try and fit the two leads myself?
      b) would me attaching a tracker to the 12V Battery drain it & cause problems??
      Hope to hear from someone soon..
      Shyamal
      Ps: the picture below shows the two leads that I'm supposed to connect to the Battery if it makes sense to anyone
    • By Arqum
      Hello peeps. So my replacement Battery i had was a Toyota Optifit which tbh im not happy with. Been 18months and its struggling as the days get colder. I bought a Ctek charger which charged it and it was ok for a day and then when i measured it across the terminals i was only getting 11.8v
      Can someone who has the original factory fitted Battery take a pic for me and if they can find out the spec and part number from the Battery please?
      Cheers
    • By WilliamH
      Had to get a replacement Battery in a hurry today for my 2003 IS 300 Sportcross, so went on-line.
      Eurocarparts website was easy to use and had a tasty discount offer. They had a choice of 2 so I selected the more expensive one with 70Ah, CCA 540A, rating and ordered it 'click and collect'. £67.40 inc vat and 3 year g'tee which I didn't think was bad.
      Now I've got it home I can see it doesn't fit the Battery tray properly. The base area is too big to fit deep in the tray so it sits quite high. Also, the new Battery is 10mm taller than my knackered Battery. As a result, the standard Battery clamp won't fit (the rods aren't long enough) and the terminals are worryingly close to the closed bonnet.
      Is this a common issue?
      Is there a work around or will I have to return it to eurocarparts?
      Is there a generally recommended/ easily available Battery that fits?
      Thanks in advance for your replies!
    • By Farqui
      Rather than keep updating my New Members thread I figured a build thread would be a more appropriate place to keep track of my changes. Especially as Robb/Mod's went to the trouble of opening up this new section for us.
      January 24th'17 - GS 450H purchased
      This is my first Lexus, my first hybrid and it's such a joy to drive with plenty of power and it's very slick CVT gearbox.  For a big car it goes/stops and handles surprisingly well.
      The rear boot space was the only concern but with just me and mrsF it's worked out just fine and 6 months down the line we've made a couple of trips over to Belgium without any issues.
      So lets have a brief recap of the initial 6 months of ownership.
      The car came with a spare key but it wasn't working, thankfully a new CR 1632 brought it back to life #phew
      January 31st - Lexus Full+100 service @Lincoln, including a Hybrid health check - was successful and warrantied for another 12 months
      The Lexus health check listed these items...
      both front tyre valves leaking - the OSF definitely is, around the base of the TPMS sensor. I can't see any leaks on the NSF rear brake pipe corroded - all I can see is a small rub on each side, looks like the inner arch has rubbed the pipes slightly front shocks leaking from body - all four dampers are bone dry tho! - I look forward to hearing what Lexus have to say about this exhaust blowing at 'Y' section - agreed, discussing this with the dealer that sold the vehicle exhaust also has a slight leak from the mid section - I couldn't get underneath sufficiently today to check this    Not the best of starts but I was prepared for some work to get an older car 'straight'.
      February 7th new wiper blades
      Feb 11th, lowered bonnet bump stops that were preventing the bonnet from closing without a really good slam.
      Updated the OEM satnag, using http://www.latestsatnav.co.uk/ - now the local roads appear. This supplier has the UK/Belgium/etc countries all on a single disk  unlike other providers or OEM (over several disks)  I needed to disconnect the 12v Battery to get the replacement DVD to load.
      Feb 14th, dashcam fitted, a Thinkware F770 dual channel that I'd been using in my previous steed.  Hardwired into the AUX circuit via a piggy back fuse on the drivers fuse board. Earthed to the forward fuse board bolt. As the fuse board is well recessed, I've left the cover off for the moment but I may cut a slot in later and then refit the cover.
      Routing the cable was quite easy and only needed the drivers side end of the dash un-clipping.  The cable was then tucked in the drivers A pillar and roof lining, up and over to the camera. Excess cable was looped up, cabled tied and tucked under the carpet well out of the way.
      As the rear sun shade doesn't run parallel to the rear screen (it starts further forward in front of the 3rd brake light) I managed to fit the camera just above the 3rd brake light, higher would have given a better image but that would have interfered with the sun shade.
      The rear camera cable was run around the parcel shelf, up and over the rear door but I couldn't get a neat run around the top of the b-pillar.  So I dipped the cable halfway down the passenger b-pillar, popped off the lower section to loop up the excess cable (out of the way of the seat belt). The cable then went up and over the passenger door and around the top of the screen to the camera.  All neat and tidy (ignore the mirror that was just pushed out of the way to show the camera install).
      Test views, front
      rear
      Feb 15th, gave the headlights a quick polish to see how they'd come up.
      Quite pleased how they came our after just a few mins work.
      Cargo net fitted, under the parcel shelf so I still have easy access to the boot (like this sample pic)
      Feb 17th, the car has been up on the ramps today with my trusted local mechanic who gave it the once over with me. All of the shocks are bone dry with no signs of any leaks or misting ANYWHERE. So for now I'm going to ignore the Lexus recommendation LOL
      The exhaust is definitely blowing at the rear Y (see earlier pic).  We also saw that the OSR box has a few issues...
      Pretty obvious huh.  Neither Lexus nor the last MOT flagged it.  It can't just have appeared in the last 3 weeks since I've owned it.  I despair.  The rear section is beyond repair so I bunged my indi some beer money for using him ramps. Looks like I'll be getting a new rear section made up in the not to distant future
      Feb 19th, new mats fitted, this Luxury version fits a treat http://www.ebay.co.uk/itm/252033676404
      Gave her a good scrub
      Including the engine bay, no treatment applied yet
      Turns out the passenger footwell has only been blowing cold, giving mrsF cold feet and making her unhappy. Before you ask...yes, we tried all options of Dual/modes/temps/etc. So after surfing for solutions I dived in to check the servos;
      Drastic eh. I eventually tracked down the passenger temp control (passenger side) but with the fixing screws out, I couldn't get the servo out :( With fading light I decided to button it all back up and went for a quick test drive. What'd'ya know, the passenger footwell is now working! The only difference is that I taped up the ducting, both sides, to get a good seal from the heater core. Result.
      The sceptic in me reckons it can't be that easy and that I'll be back under the dash before too long. Which is just as well as I have a few screws left over Never finish up a job in the dark!
      I didn't get anywhere with the heater on Saturday afternoon, so buttoned it all back up and thought the mode control was roughly working.  Nah, on a 5am commute the other morning clear screen setting kicked in (I didn't test that earlier) and the heater did zip all except vent to the rear seats! For the entire 4hr round trip
      At lunchtime I went back to basics and figured out what lever on the heater does what. I also removed the 2 servo's/mounting plate and let them do their thing.  Once I had a grasp of ALL the settings (temp, modes) I set all levers in roughly the right setting, lined the mounting plate to the heater arms (no easy feat), restarted the vehicle and the first test failed
      I have noticed that when you turn off the ignition, the servo's sit for a while and then revert to some standby setting.  I think this has been throwing me off so I removed the servo plate, set all levers in roughly the right setting again, fired up the ignition and let the servo plate settle.  With the ignition still ON, I aligned the mounting plate to the arms for the umpteenth time and gingerly pressed a different mode button...
      The first test worked and the servo's didn't bind. So I tried another mode setting and that worked.  Trying not to freak out, I carefully went through all the possible combinations and to my delight they all work
      The passenger side footwell output is still hopeless tho I think I may know which control needs a slight tweak but then it may just be the way the airflows. So rather than dismantle it all again I reckon I'll buy the mrs a heated blanket/mat or fan to keep her feet warm.
      To help align the 7? heater control arms to the servo plate I found one of these cheap endoscope camera's quite helpful to help see around corners http://www.ebay.co.uk/itm/122076843254
      Oh and this time there are NO spare fixings left over
      March 9th
      Yesterday I had the...pleasure? of exploring Leeds city center whilst my car was left at Tony Banks for a new exhaust.  To recap the rear section had the usual split and a gaping hole in the OS muffler, so we definitely needed a new rear section.  I knew the middle section had a slight blow and when Tony removed the rear...the middle section decided to snap in two! He spent around 6 hours (elapsed) crafting both sections from stainless.  The cost of a new center section (with cats) was so tempting that I was already half tempted to get the whole lot done and then I'd never need consider the exhaust again.
      I didn't want any fancy or annoying noise so chose a standard set-up and driving around town you'd struggle to tell this system from OEM.  Under hard acceleration or at dual carriageway/motorway speeds there is a slight increase in noise, which is no bad thing at OEM is really quiet.  The system should quieten down a notch once it's coked up a bit.
      I didn't get back to the work shop before the car came off the ramps so I haven't had a close look at the system but from what I can see it looks dandy.
      The chaps were helpful and have plenty of varied work coming through the workshop, including a steady number of Lexus.  Overall I'm impressed and wouldn't hesitate to recommend http://www.tonybanks.co.uk
      March 17th OSR tyre flat - punctured, replaced with an Avon ZZ5, managed saved the TPMS and fitted a new valve.  OSF leaking needed which on investigation then a new TPMS sensor.
      April 2nd, cleaned/lubed rear calipers. OSR stone guard is badly corroded
      April 21st, paint correction/protection;
      July 6th, fitted 3M tape and a roof rack before the heavens opened. It'll allow me to get back on the bike and hit some nice trails, once I source a carrier.
      Found a great heavy duty bag to store the rack, http://www.ebay.co.uk/itm/263068408736
      If you want any more details about anything above, then check out my opening thread;
    • By Nickyt211
      Hello this is just a question out of curiosity, I've cleaned and polished my new rx300 2004 plate I've had it 2 weeks now and I believe it's running on it's original Battery it looks a bit old tbf, it's a Panasonic Battery and it says distributed by Toyota on it. It can't surely have lasted this long can it? Lol
      My question is which Battery do you guys think would be up to the job, which brand do you recommend. Just interested in makes and models etc. Thanks
