Squeaking Noise When I Use The Accelerator
andyboroboy
post a video if you can. I would like it hear it.
If not is it something like this :
Watch "2007 IS250 Engine Noise" on YouTube -
If it's the water pump get it done before your engine overheats, I guess.
Sad Lexus is just any other car.
has the engine over heated by any chance ? UK weather won't allow it to over heat easily but if pump is not working then water isn't circulating in the engine. Can you check the color and amount of coolant you have? Only do this when engine is cold. There is DIY on US forms for replacing the pump. Let me know what a garage quotes you.
Also, does it come cheaper if you buy your own parts ?...
I won't drive the car around anymore .
Cheers jack and no the car has not overheated. I just topped up the coolant a few days ago.
The noise really only started a couple of days ago just as I was thinking about part x ing for an F sport I have had my eye on. The Lexus garage offered me a grand less than I was hoping for due to the engine problem.
Had the work done today and the car is now working fine. New water pump £311 fitted. My is has done 86,000 on a 55 plate.
Might keep the old girl until after xmas now then start a fresh looking for a newer one.
