Todays The Day
Morning chaps :)
Photo's added - and yes it's fine thanks.
Need to get used to the slightly harder suspension than the Citroen which I expected and the throttle pedal is very sensitive but apart from that its just the job.
Checked all the tyre pressures this morning and they were :
Rear Nearside - 36
Front Nearside - 41
Front Offside - 35
Rear Offside - 33
Hmmm............ (Fairly accurate digital gauge)
I have set them all to 34 - is that OK ?
Congratulations on the purchase, I bet you have this silly :D grin every time you drive it.
I run mine at 34PSI and when I took it in for its 1st service the garage reset them all to 32 PSI.
These should have been checked and set to 32 PSI during the PDI at the dealership.
Where did you purchase the car from?
Dont forget to check the spare.
Hi
I haven't been there for ages - got a bit bored.
This Lex certainly beats the old C5 into touch, no rattles and the whole thing feels a lot tighter :)
I've got it all cleaned up (to my standard) and my first real journey will be tomorrow (Monday 12th) and they have forecast heavy gales and a storm - typical :(
The only cleaning problem I have found is trying to get behind the rear speakers and high level brake light - any tips ?
