New Firmware - May 2016
  • 4 weeks later...
Did the update tonight folks.
Struggled at first. The memory sticks I was using were not being detected by my vehicle.
I eventually got it to work.
Firstly: My 32GB USB 3.0 key did not work (Samsung)
Secondly: My 8GB USB 2.0 key did not work (SanDisk)
Finally (succeeded): My freebie, 10 year old, no name 4GB USB 2.0 key worked fine.
I think it's important for the key to be 4GB or less.
I noticed today that the firmware has removed a feature. So far, I can't see anything new or any benefit, and some glitches I had hope were fixed are not (the volume up / down causing tracks to restart, etc.)
When playing music via phone, I used to be able to browse playlists using the mouse (select another playlist, see a list of songs).
That browse button is now missing from the interface.
I'm using an Android device with Google Play Music.
Disappointed.
Can we roll back firmware?
I was running Android 8.0 and 8.1 without trouble and had the browse button working just fine.
I'm now on Android 9.0 as of a few days ago.
Perhaps that's the culprit rather than the firmware.
I'm using a Pixel 2.
Delete the app data for google play music and then try playing something, should be listed under Apps > Google Play Music > Storage.
The specific setting that causes the issue can be found under developer options > Bluetooth AVRCP Version >
AVRCP 1.3 is fully supported by Lexus, 1.4 onwards causes problems.
Hi all,
I can't find firmware version VD12104B on www.lexus-tech.eu
Latest firmware version there is VD12103A. Do you know how can I download the latest version? Should a use a different bulletin number?
Thanks,
Bruno
2 hours ago, BrunoLeal said:
Hi all,
Thanks,
Bruno
No it isn't available that way. Someone has extracted the files and shared them on the previous page of this thread.
On 8/11/2017 at 6:39 PM, winrris said:
Ok. Thanks. I thought that it's not going as it should because earlier someone mentioned that it's taking few minutes. There was a progress bar when the files where copying but then it stoped.
It's over 1 hour now. I just hope that it will update successfully.
Hi. Did you manage to resolve this? Thanks
47 minutes ago, wakhtar said:
Hi, Did you try changing AVRCP to version 1.3  via developer options on your phone?
You suggested this a few posts up, and I said I'd report back, but I can't see that I did (I though I did).
I changed to 1.3 and there was no difference sadly.
A real shame...
A real shame...
indeed, a friend of mine who has a pixel 2, tried the same and the playlists were displaying ok, interesting.
I'll try again!
Did your friend do anything else other than tweak the version number?
4 minutes ago, matt8 said:
I'll try again!
It was the first time he had used google play music so maybe delete the data from storage (Apps > Google Play Music > Storage) and then try again.
Maybe try spotify and see if thats different,.
  • 2 months later...
I updated my CT200h with Premium Navigation Gen 1 to VD12104B. The update installed without errors. This seems to be an option for firmware when you look at the Bluetooth compatibility on the Lexus website.
This may of been a mistake and probably should of gone to VD12103A after finding service documents on the portal.......
I ordered a Nav Update SD card to update too  PZ445 US335 0R and this fails to load the update I'm fairly sure it fails on the firmware update part as I have extracted the firmware and tried to update it without the Nav data and it fails in the same way, asks me to contact service .
Has anyone had any issues like this ?
Is it possible to downgrade firmware  ?
23 hours ago, jrumball said:
I updated my CT200h with Premium Navigation Gen 1 to VD12104B. The update installed without errors. This seems to be an option for firmware when you look at the bluetooth compatibility on the Lexus website.
So I can Partially answer my own questions seems like the SD Card may of been corrupt, the seller sent me a new one that worked and updated correctly .
My software version is now VD12105C, I haven't noticed any changes....
  • 7 months later...
