I have a IS250, 2012, and the windows mist up in seconds when the climate fan is on if the air con is not on.  This happens both in winter and summer.  Any fixes out there.
If you haven’t used you AC for a while it might smell a bit funky when first used, also check that the cabin/pollen filter is good ( not blocked or damp) and preferably use a activated charcoal type to reduce the build up of bacteria on it.
paul m
