Inverter reconditioning ???
I would imagine that, just like any other electronics, they should be repairable but access to spares and schematic diagrams may be the problem.
Ok so i bought a second hand unit on eBay 400 pound, the guy came and changed it over and charged 350 euro for the job wich took him about 2 hours, i still have my old inverter he rang me to see if he could take it for research he says
The inverter contains other items apart from the actual drive system for the car. It also contains "as separate circuit boards" the DC to DC converter to charge the 12 volt Battery, the inverter drive for the AC compressor motor, and the buck boost converter that boosts the Battery voltage from 288 volts to 650 volts. On there own these would be useful items to keep in stock to repair other faulty units.
It is also possible that just one faulty FET " a type of high current transistor" would be a likely cause of breakdown of which there are many in the invert. Good one's could be removed to repair another inverter.
John.
1 hour ago, Alan64 said:
Ok so i bought a second hand unit on ebay 400 pound, the guy came and changed it over and charged 350 euro for the job wich took him about 2 hours, i still have my old inverter he rang me to see if he could take it for research he says
Wow, 175 Euro per hour labour! Not bad work if you can get it eh?
this equates to slightly under the full Lexus Main Dealer hourly rate too incl the VAT :unsure:
WOW, the old unit must be worth to him, shall we say, 150 euros maybe :wink3:
was I reading the price of a brand new unit at about 13000 euros from another post by Steve ?
Yes very expensive and he was the only guy i could find in dublin doing hybrids, so do i tell him to stick it or try sell it to him or give it to him and tell him he ows me a favour🤔🤣🤣
Yes, I know, that's why I was agog with shock - you don't expect any other mechanic/garage to charge main dealer rates.
I know i was a bit shocked at the price but just relieved the car was fixed, i couldnt find any other hybrid specialists so im thinking maybee keep this guy on side, i have messaged him letting him know if he wants the inverter he owes me a good rate if i need another job doing
I think it is a case of supply and demand. He can clearly get away with those rates for that reason. If the faulty inverter is of no value to you, I think you have made  a sensible decision. Cast your bread on the water !!! 😜. Good luck, Cheers, Roger
