18 minutes ago, rich1068 said:
Put the torch hard up to one side of the tank and look through the tank from the other side. Nudge the car as you're doing it and ideally you should see the pink coolant moving.
I tried, nothing. I think there’s none there
Got some coolant from Toyota, topped it up. It wasn't extremely low, as soon as I started pouring it is I could see it at the bottom of the expansion tank, so the level was just underneath where that starts. Booked in for checks on Monday.
So I topped it up at lunchtime to just under the full level, left it until just now, checked again - still at the full level, no marks on the ground. Drove it for about 15mins a mile down the road and back. Checked it idling with the AC on, didn't seem to be overheating. The coolant level has dropped by about 1cm from where it was though - is that likely just because it's hot or could it indicate the coolant going somewhere? I'll check again later when it's cooled down.
After cooling down it’s low again, once again below the visible area on the expansion tank. Seems like it’s losing coolant fairly quickly but still nothing visible on the ground or anywhere ai can see in the engine bay. Gonna avoid driving it until I can take it to the garage.
I actually didn’t realise i also needed to fill the radiator through the radiator cap, started filling that this morning and that took a fair bit too. I reckon i’ve added maybe a litre so far.
Yeah you need the main system full before measuring the drop otherwise anything you put in the expansion bottle will just be used to fill up the system. If your top hose wasn't full then you have lost quite a lot of coolant so that all needs to be replaced, then you can see how quickly it is being lost.
Yeah, I filled up the radiator and took it for a quick drive, not very far at all. Came back, expansion tank level looks about the time. Will check it again tomorrow.
It's all fairly academic at this point as there's very likely a leak somewhere so it's going to the garage on monday, but will still be interesting to see just how quickly it's leaking. Apparently there are a couple of places where it can leak without pooling on the ground.
The loss isn't as dramatic as first thought. After my quick drive yesterday it was still basically full, barely took another half a cup this morning.
Does anyone know how the temperature gauge is calibrated, i.e. what temperatures the notches on it equate to?  I know the middle is the normal operating range, and it's probably a range rather than a specific temp. Just trying to figure out what the potential impact is of getting up to the notch before the top. Since there was no check engine light and the car seems to be running fine I'm hoping I got away with it but still curious to know what the calibration is.
Zero impact, you have nothing to worry about. You don't get engine damage unless you notice a loss of power and/or pinking and you continue to drive for several minutes in that state. That situation doesn't occur unless the temp gauge is off the scale.
That is good news - thankyou. Someone else suggested changing the transmission fluid and oil pre-emptively just on the offchance they got a bit hot, what do you think? Both are fairly fresh, transmission was done last year and the oil about 1000 miles ago. I don't think it was hot for very long so I'm leaning towards just leaving those but.. not sure.
No reason to do the transmission fluid, it is self-contained with its own cooler - it doesn't even have the cooler inside the radiator like on some other Toyota/Lexus vehicles. Therefore its temperature wouldn't have increased because the engine was hot. The transmission also has the capacity to tow a trailer so it has plenty of tolerance and cooling capacity. If the fluid is black (rather than dark brown which is tends to go) and smells burnt then it should be changed.
As for the engine oil then if it was a good quality synthetic oil it would easily cope with a slightly higher temperature. Personally I wouldn't change it but you seem particularly concerned and it is an easy thing to do so you may want to go ahead.
I'm not sure there's a transmission cooler on mine, haven't seen one anyway. It's a Harrier, so not allowed to tow with it because there's no weight specification on the V5 or the vin plate. I'll check the fluid though.
I've assumed you have a UK supplied vehicle which all have the transmission cooler. Harriers don't unless they had towing pack installed, but in any case the transmission wouldn't have been overheated because the engine was running hot.
I've a feeling it may have been getting low, the hot weather has done for what you had left in (diluted coolant maybe?) and you needed more or less a complete refill. Topping up into the expansion tank was just going to the rest of the system.
Just one of those things possibly?
I've never had to put coolant in before, in 3.5 years of owning the car. Coolant was changed by the garage 3 months ago, then suddenly over a litre was missing. It had to go somewhere.
I've followed the question from m4rkw and the feedback from NemesisUKColinBarber & rich1068. I have a Lexus RX 300 SE, 2005 LPG which is also overheating. I have broken down four times in approximately 12 months. I've parked her up with the expectation of replacing the engine due to a suspected head gasket, which I've been advised would require a replacement engine as the garage I use wouldn't bother replacing or skimming the engine head and new parts etc. Anyway, I've ordered the pink coolant today, to monitor where the leaks are coming from with a view to saving my car as it is incredibly reliable and efficient, but for this unknown issue. I'm reluctant to sell her, but I will if required. The garage I use kept asking me to monitor the amount of coolant which I did. The breakdown recovery mechanic said the same, but eerily none of them ever mentioned the head gasket which I found extremely odd. What are your thoughts other than what you've stated to m4rkw?
A hydrocarbon test would confirm head gasket diagnosis.
Agreed.
Also Antonio, if you take the oil filler cap off, does it look a bit like mayonnaise? That can happen with head gasket failure although not exclusively. Mayo can also be due to condensation if the car olny does short trips and temps are low.
