Rod Millen Is430
johnboy
  • Replies 59
  • Created
  • Last Reply
Top Posters In This Topic
Okay, I've watched the program and it's recorded fine. I need to record it onto DVD and I'll then create an iso image and host it tomorrow morning.
I will allow http, ftp and bit torrent downloads.
Remember this going to be around 2GB so using a 512kb broadband connection is going to take 10+ hours to download. I would recommend using bit torrent as it can recover and carry on where it left off if any errors occur.
I'll also try lowering the quality to reduce the filesize if people request it.
The ISO image either needs to be burnt to a DVD via Nero etc. or run an iso mounting application like alchol 120% or the free software that you can download from my page.
Matt, I'm testing a http download from my PC at work - seems to be working so far.
I would recommend people use BitTorrent as you can stop your download and carry on where you left off or recover from crashes etc.
its the http download I'm having trouble with Col - never manage to download the full image - around 30 meg is the most I have had.
BitTorrent is probably the best bet - I would recommend that too mate.
I was planning on using the really fat pipe here in work to get the download today, then copy it to my laptop and help out seeding the torrent.
