Fog Lights
fenderguy2
I just got a black '02 IS 300 and I was wondering if anyone has any suggestions on what type of fog lights i should get. Do i have to change the whole light or can i just change the lightbulb. I dont really like the stock yellow so i would like to match them up with the stock headlights but if anyone has any other better ideas please let me know
The fogs are coloured inside the lenses......you'll have to go thru the painfull process of removing the foglight clusters (by peeling back the inner wheel arch liner and going in thru the back). Then separate the lens from the cluster by the oven method....
Then rub the inside of the lens down with progressively finer wet n dry paper until you've removed the yellow film.
Interesting tho.....in the US, they have clear fogs on the IS300 and are all clamouring for our yellow tinted fogs!
Get yourself a HID kit and replace it with the fogs. Like so:
You might be able to remove the yellow film using paint stripper,it worked for me
