Touch Up Paint
ALI_1
You can get this from the dealers, have a word with them as you'll need to order dependant on the colour of your car, the paint code is located in the engine bay on the metal plate with VIN number etc.
It's not expensive, something like £10 - you get a small pot of paint and a small pot of lacquer, it's really easy to apply, do the paint first, then leave for a bit, then the lacquer, job done :)
If only :)
I've got tiny little raised bobbles of paint which are very difficult for the amateur to rub down. Also the supplied paint (Lexus Montrose Blue) is darker than the original finish.
Here are the paint codes translated should you need them (paint names will differ but codes will still be the same):
2003 - onwards
062-White Crystal
1C0-Millenium Silver
1C6-Graphite Gray Pearl
202-Black Onyx
3P0-Absolutely Red
576-Solar Yellow
585-Cibola Gold Metallic
6R4-Electric Green Mica
8N8-Intensa Blue Pearl
2002
062-Crystal White
1C6-Graphite Gray
202-Black Onyx
3P0-Absolutely Red
576-Solar Yellow
585-Cibola Gold
6R4-Electric Green
8N8-Intensa Blue
1998 - 2001
202-Black Onyx
576-Super Bright Yellow
3N3-Red Mica
1C6-Dk..Gray Mica
051-Diamond White P
6Q7-Dk. Green
8M6-Spectra Blue
There is no obvious visible plate when I lift the bonnet of my (Argento Ice) IS 250 SE-L. I assume it is tucked under one of the plastics covers. Does anyone have an accurate location please?
chassis plates or labels as they are now are just inside the passenger door (have been since 2003)
