Hks Sld On A Altezza Tip
altezza __rs200
I have an SLD2 (SLD 1 is for manuals only) fitted to my tiptronic as RSM's won't work with Auto's.....
it doesn't work 100%, it will allow you to go over 180kph but it effects the revs in 4th gear as it will now not rev to 7200 and will auto change up to 5th earlier which makes it take longer to MAX out....
would i buy one again.... nope, not worth it
@Lee, surely an old airfield around somewhere :whistling:
I've noticed that with the box in auto but what happens if you hold the range in 4 with the tip?
it'll still show "4" in the display but you can hear and feel it change up to "5th" .... :(
I had a look at this ECT Controller but didn't get past that stage.
Looks like you can programme the box to do what you want including tiptronic shifting.
Is that controller saying you can turn any auto transmission into a "tiptronic"? Sounds like a cool device if it is.
with mine when you put it in tiptronic mode you can change through all the gears when its in fourth gear you can keep your revving till it hits the rev limiter, then you can change it to fifth but when you do that you can only accelerate a little bit, cos if you going in fifth at 4000rpm and you put your foot down it will automaticaly change back down to forth gear and stay on the limiter, this can become very annoying and its not that good for the engine too,
