2002 Is200 Head Unit
Hi all
my head unit really p!55es me off#
sometimes it works and sometimes it doesnt it is really annoying
i know its a common problem i used to also have this problem with my 1999 is200 sport
anyway whats the solution? my cars of road at the moment (check my other thread) and i want to get it fixed before it goes back on the road
thanks
Hi i had the same problem with my 2001 is200.
if you have the same problem err3 its because 1 of the cd carriers maybe twisted but this is very easy to fix.
all you need to do is remove the top cover, the cds wil be on top just re sit the carriers and replace the top it will work fine
this will not work with pre 2001 as the cd changer is under the cassette player.
hope this helps
