Heating Problems
If it has dual zone I would say one of the servomotor flaps has failed, there are quite a few of them which control the airflow direction like windscreen and footwell and others which control the mix of hot and cold air.
Mine did this yesterday. I had it set to windscreen and feet, but had all vents open. Driver side was hot, center and passenger side were cold. Feet and windscreen were fine.
Don't want to sound patronising, but before bleeding the system, have you checked that it's not something silly?
Stuart
Hi mate did you fix the issue? If so what was it? As i have just bought my 2nd is200 and am having the exact same issue..... at first i thought a airlock so did a coolant change and made sure was all bled and still no change.... any ideas ppl?
