New Owner After Advice Please.
Hi Guys
Just bought the first of the facelift LS 430's it is registered on a 53 plate end of September 2003. Everything works on the car apart from the camera only works intermittantly and does not most of the time. I am not too concerned but was wondering if anybody else has had that issue and fixed it for reasonable cost. Lastly does anybody know if all facelift LS430's came with Bluetooth at all as do need it but did not check as forgot. Looking forward to getting it over the weekend as had a lot of Japanese cars but never a Lexus.
Thanks for your help.
Hello and welcome to the LOC.
I seem to remember previous posts regarding the reversing camera on the LS430 and from that there have been reported problems with them. Lexus will simply replace the camera unit in exchange for many pounds.
If it is intermittent it may be worth giving the camera a tap with you hand to see if the fault appears/disappears and check the wiring to it.
I don't think there are any direct aftermarket replacements but if you may be able to get it repaired at a TV repair shop ( if there are still any out there!)
I was going to get a guy to check the wiring hopefully that will do it. I guess it just wires into the reversing lights initially so may have a look there myself for anything obvious although I am not at all handy with stuff like that.
I cant help you with your problem but welcome to the LOC for life. Another converted motorists who has discovered the best kept secret in motoring and will never be the same from this day on.
We are a friendly bunch and I know someone will be able to help you. Mike
Cameras have an issue with water ingress, camera knackers itself down.
Only option is to replace it. Eventually you will be left with a blank screen with the guidelines when reversing.
Ok well look into the second hand cameras that are on the Toyotas, they have the same connection and a bit of messing around could be a close to a direct swap.
