Square Under Wipers On Is220
I think you are all wrong, this should be rain sensor, to turn on whipers, if you are talking about the little circuite od center of dashbord
I think you are all wrong. Its the light sensor for automatic lights. If you put your hand over it after a few seconds your lights will turn on if you set them on auto.
Sensor for wipers and lights should be up top of screen behind/front of rear view mirror. The wires you see at the bottom of the screen are the heaters to defrost your wipers when it is chilly outside. Why they don't have a fully heated screen beats me.
