Sign in to follow this
PhoneDrome
Problem Acceleration
I think I have a problem with acceleration in revs over 5000.
My car goes well until it reaches 5000 1/min (in every gear). Then you can see that there is less power.
I reach 190km/h quick and then its like riding a snail. Even don't get my car over 210 km/h or into the limiter (like ever before). It takes veeeerrryy long to reach 210 km/h. Normally the cars goes up into the limiter, driving around 225km/h.
My last mods where a new catback and bigger tyres (225/40R18). Both mods where done at the same time. So I don't know what gets me this problem.
What do you think gets me this lack of power?
For me I think I have a problem with the exhaust-system (pressure or interferenz?).
Perhaps I have to swap my wheels back on winterwheels and have a test-drive. :yack:
Thanks for your suggestions.
Andi
Does it feel like a sudden loss of power when you hit 5000 revs or is it just a gradual thing? Could be a loss of pressure but I would have thought this would be just as pronounced at lower revs too. Have you tried reseting the ECU? If it feels a bit like hitting the limiter then it might be that the ECU has picked up a problem.
I doubt a change of tyres would make any difference.
Its a sudden loss. You can see the speed-needle increasing and suddenly it goes up a bit slower. Happens around 5000-5300 revs. Just when the engine is at top of power output.
I did a ECU-Reset yesterday, drove around sporty but no difference. Very slow acceleration from 190-215. And I don't get her at topspeed.
Engine light went on twice yesterday. But only when accelerting in 6. Gear between 100-140km/h.
Didn't apear since the ECU-Reset.
If it's a sudden loss then it sounds like the ECU stepping in.
Either the ECU thinks something is wrong, or there is something wrong - either way, I think your only option is to have Lexus take a look at it.
(I'm guessing there's no cheap/easy way to have a look at the ECU diagnostics).
If the engine light is coming on then you need to get the fault codes read
So, I have to wait 'til it comes up again. Because of the ECU-Reset the register was cleared.
Is it possible to read the fault codes like it is done in this link? Lexus
Is your ACIS valve working - do you still get the 'kick' between 4000 & 4500 rpm?
Yes, your IS200 is a 99 isn't it?
It'll have OBD2 so you'll need a diagnostic reader (and they're not exactly cheap!).
Yes, it kicks at 4500 1/min.
I think, I'll have to wait until the check engine light comes on again and then get her to Lexus.
You can only read via OBD-II not the simple method.
PC based OBD-II readers can be brought for £55 upwards.
is this since getting the budinski exhaust.if so check the main exhaust lambda sensor wires.
Jens had this problem on his after fitment of the budinski exhaust, the lambda sensor wires were all twisted up :angry:
This morning I had her out for a run. Speeds up through all gears very fine exept in 6th gear. So I think my little problem comes from the bigger wheels. Max speed 218km/h.
I'll have a look at my lambda sensor.
I have those same size of tyres on my car and there is no problem reaching top speed.
I got 18'' 225er wheels and I also noticed serious problems to hit the 215 area.
It pulls great up to 200, but then it's like the brakes engaged and it takes hours to reach 215 or more.
With stock wheels I didn't have problems to get the needle to 215-220kmh.
In my opinion, bigger wheels have more aerodynamic resistance and more frictional resistance, so comes less max. speed. <_<
I have Uniroyal RainSport 1.
Very very Quite, high grip tire. I like them very much.
