Oh dear.....warning Lights Came On
Driving back from Hamburg yesterday with Hart'y.....at 30mph cos the tree huggers forgot to salt the autobahn
pulled of to have a break...when the "engine check "lightcame on and the "trac off" light started flashing,the rpm rose to 2500rpm and any attempts to alter the rpm with the accelerator pedal did nothing..as if it wasnt connected.
so we pulled the ecu and trac fuses....and then replaced them a few moments later....
switch on the engine...still wierd,but the hanging rpm has gone.
pull of at the next services,pull the ecu fuses again..go for coffee....fag and Number 2,......so 30 mins later replace the fuses,car starts fine...no warning lights...woohoooo
HOWEVER.....
this morning getting the car ready to take Hart'y to the airport and the engine lights come back on....and all attempts to reset are doing nothing....******
and everywhere is closed now.....could driving at 30 mph for 2 hours caused it???
i know we were driving in freezing rain....dodgy as poo
but what? how? when?.......and why?
******......******:unsure:
car drives fine.........
could it just need the fault code memory clearing........
******electronics...
Driving at 30 mph for 2 hours will have no effect on the workings of the car only your fuel economy,
Sounds like to me that a bit a moisture has got in somewhere and frozen,
The reason why everything was OK after you stop at services for 30 mins, 'Hot engine soak' could have dried out the area that was giving the problem, resume driving OK, after parking the car over night heat soak long gone, any moisture will freeze and possibly causeing the problem, I am assuming Over night temp well below freezeing.
Just a thought
OK - can't believe I am giving you advice on the IS200 - but here goes!
I can categorically state, without any fear of contradiction, that driving @ 30mph for 2 hours (or more) wil not cause any damage to your car.
This may be a novelty to you mate - but for some of us, this is nothing unusual (sometimes 30mph is fast).
if you need anymore help Mat - don't hesitate to ask
Mat, just a question, do you bring some liquids in the boot ?
Maybe some humidity in the boot near the electronic box…
Appears once to me on the IS200, with a (censored) opened bottle of clean glass liquid in the boot.
All the lights came on, hopefully letting the car opened in the box and using a hair dryer solved the problem.
Can you not get the error codes out of the ECU?, which may point you in the right direction.
Sound like you got damp in a connector somewhere, so the system was giving faulse messages?.
:duh:
Just my thoughts
its moody, the car and supercharger are unhappy about the 2JZ-GTE swap
Hmmmmmm,it seems so,Get the car out the garage..lights on still,drive to the house lights still on,drive to the petrol station,lights still on,filled the car with petrol,drove 3 km down the road on the way to the dealer,lights still on,.........."oh look" the lights gone off :angry: Turn around come back home
bloomin car...... :blink:
well its booked in for its 20,000 mile service on monday,will get them to check the ecu memory
hmmmmmmm,had the ecu memory read this morning, the faults were..........
ECU Main (engine)
Trac/abs
Immobiliser
Aircon
so not to much to worry about, infact the only electrical thing not to show a error code was the folding mirrors.
anyway its all been reset now.......... :yahoo:
Toook the freakin car to the dealers again today.....cos the freakin lights are back on.........
apparently its the main cat thats failed........so ordering a new one,
me thinks Lambda sensor...........(on/off fault......hmmmm)
so anyway new cat is on order.leave dealer...lights still on......drive around for an hour or so, get within 100meters of the house........LIGHTS GO OUT :angry:
so,now i defo think its the sensor and not the freakin cat.....but will find out on bloomin tuesday.....again
another 80km drive :yawn:
