Stick on aerial on front screen
If it's sort of rectangular, it's a DAB aerial. I had one on my old Nissan when we fitted a Pioneer unit. I really miss listening to Planet Rock but that's the problem with cars these days - because everything is shaped and integrated into the dash, nothing else fits or looks right so I'm left with just FM/CD and cassette in my RX300.
Yes I have one and it works well. The trouble with DAB is that coverage in the UK is awful. Its like everything thing else we do in this country, just half the job and even that's done badly. Mike.
It is often a Dealer fit upgrade to get DAB properly integrated with a Toyota/Lexus of this vintage, though i don't know if the pre face lift infotainment system can handle it.
Its not really visible and the way it works is that one part of the aerial picks up the digital signal and the other part of the aerial transmits it to your normal car aerial. Your radio is tuned into what ever waveband the Dab tells you to tune into. Mike.
OK. Mine is totally visible with a little black box about 20mm square, with two 'elements' that stick out about 200mm towards the rear view mirror. I'll try to get a photo later (if it's still daylight up here in Scotland).
Quick question in relation to this. has anyone with a pre face lift car got the ipod kit and dab module fitted. can they be both fitted or is it one or the other??
I might be wrong, but I though that the standard DAB kit was a dealer fit kit, primarily because of the software update, whilst the in built iPod capability was factory fit. So I think that if you are after an iPod connection the only route is the aftermarket.
