Pressure washer
  • 1 year later...
I would not use I power washer. although it might prevent swirls on a filthy car... This weekend I've washed my car, and for the first time i've used a pressure washer. Although I kept distance, i discovered a lot of new paint chips. even on the door. So depressing
Probably washed out the SRP that was masking the chips etc..
Discovering paint chips is not bad thing, it is not like pressure washer caused them - they were there all the time . Obviously, some common sense is needed when using pressure washer, but it is almost impossible to cause damage with normal pressure washers for personal use. Good accessory is foam lance - cover it in foam and let the chemicals do their job before rinsing - all around the best way to prevent scratching and care for the paint in general.
As for the issue with pressure washer above, I had similar issue when using Kercher from the bucket. It simply spread water quicker then it sucked it and was stuttering, as such I found I can only use it when connected to the tap to add some pressure to the inlet. After connection I would normally press the trigger before powering the washer ON to the water fill-up hoses and the washer itself, and get rind of air bubbles. Then if the hose get bent or otherwise blocked it would start stuttering from time to time - but that generally indicates the issue with water supply for me.
Ah mate, thats not true
My wife's previous car has a little chip in it. Used the pressure washer, nothing special just a home use karcher and it turned the chip into a 5cm diameter blob
I think we talking about different things here. If your paint is failed then you run a risk of further damaging it - agreed. On normal paint the pressure washer would not cause any damage... unless you deliberately going to try it.
I believe that in my case, the pressure washer removed the touch up paint I had. I'm not sure, and I might be wrong. But I'm sure that I've never seen the chips before, and I hand wash my car weekly, so I should have noticed them.
5 minutes ago, ColinBarber said:
Typically you shouldn't pressure wash fresh paint for a couple of months.
Have you applied a filler/polish (e.g. AutoGlym SRP), it could just be it that has been removed making the stone chips more obvious?
To my knowledge, the paint wasn't fresh. I imported the car from the UK. It arrived in Malta late July 2017. I applied SRP when it arrived and in December, but there were no stone chips. Also if it didn't even correct/mask the very light swirls, I don't think that SRP would cover the stone chips or make them less obvious. Having said this, I might be wrong!
