Is your F 100% stock?
Is your F 100% stock - NOTHING changed?
26 members have voted
  1. 1. Is your F 100% stock - NOTHING changed?
    • Yes - 100% stock. COMPLETELY as it left the factory
      13
    • No - I've modified my F
      13
Sometimes I wonder if I am the only one running a 100% stock F. I know this can't be true, but I thought I'd just check the stats via a poll.
For those that have modified their cars, feel free to list what you've done.
Yours is just chavved up at the factory. ;)
Quicksilver trumpets. That's it.
Want a lexon diffuser but can't get round the shipping costs at present.
3 minutes ago, Comedian said:
Yours is just chavved up at the factory. 😉
Thought you’d messed around with the engine?
Put intake on and took off again. It improves peak power I'm sure, but feels like it takes a bit off the bottom where it's more needed.
Before I vote, are Lexus illuminated door sills classed as a modification or an accessory ?
:w00t:
Depends if you're going to tell us where you got them and send pics. Are the plugs already in the car?
LOL...sorry I don't have any pictures of them fitted. I bought them from here https://www.ebay.com/itm/Lexus-OEM-Factory-Illuminated-Door-Sills-2pc-set-2015-2018-RC350-RC-F-/231912833808?hash=item35ff150310 no way I would pay UK dealer prices for something so aesthetic.
There are no plugs, and although I loathe the things, they actually use Scotch-Lok connectors to tap into the current wires. It's probably the one time where Scoth-Lok's are appropriate because you can then remove easily enough.
Just now, Ashrez said:
Mine is completely stock. Although, seriously considering an aftermarket exhaust at the moment. Something that isnt obnoxiously loud. So i can enjoy the V8 in low revs :driving:
Don't bother with an exhaust. Just do a resonator delete. Speak to @Mark G
I know I am not allowed to post here I guess ( I am sure), but @Flytvr - you need to specify what modification is e.g. I don't see performance brake pads (e.g. yellow stuff) as mod, surely then non-stock tyres (what were they Brigetone Potenzas?) are much bigger modification, yet nobody considers that to be mod!
My points - some changes doesn't make car modified, some other does - so what is in and what is out?
I personally wouldn't worry about pads and tyres.
Definitely visual elements / engine / exhaust count
I know I am not allowed to post here I guess ( I am sure), but [mention=56229]Flytvr[/mention] - you need to specify what modification is e.g. I don't see performance brake pads (e.g. yellow stuff) as mod, surely then non-stock tyres (what were they Brigetone Potenzas?) are much bigger modification, yet nobody considers that to be mod!
Michelin PSS is stock. Potenza are garbage. IMHO.
