Lexus LS430 - Suspension Issues
My car's air suspension seems to have problems. It's become onesided recently, and the mechanic suggested that the rear height sensor and suspension components need replacement. They've advised switching both the front and rear from air suspension to coilovers now.
TEIN FLEX Z COILOVERS LEXUS LS430  (Parts £780 + Labour charges of £600).
Any thoughts/advice would be greatly appreciated!!
Hi
Yea Tein will be okay, people tend to normally go for conventional shocks from Rockauto or BC coilovers.
Have you also fitted a separate gearbox cooler? If not, I'd suggest you do it as the ls430 suffer from gearbox failure due to coolant leaking from the radiator into the gearbox
Just to clarify, I fitted the coil suspension system to Steve's car above and it really is a simple job. Absolutely nothing complicated about it.  You simply remove the air suspension fuse to stop any warning lights.
The same colour as one of my previous LS430's, and in my opinion the best colour. The labour you were charged sounds fair to me, especially as the rears would involve removing the rear seats, well at least the base cushions and part of the backs. Did they stop the suspension warning coming on?
Yes, they stopped suspension warning coming on and performed wheel alignment as well. I believe anti-seize type lubricant or wax was applied to the suspension to avoid any damages due to height adjustments.
15 hours ago, Lexus_2023 said:
Car looks much better now, ride is slightly harsher than I expected, happy with the suspension though!
You now have new suspension all round for the cost of a single air strut, and it should last for many years. If you had kept the air suspension you may have been wondering which component would be next to fail. I did this job on my car. I agree that the ride is not as smooth but it made sound financial sense.
Yes, I agree with you. Garage guys advised me the same. Their recommendation was that if I kept the air suspension, there is a risk of potential issues with either the height sensor or suspension components, which would require frequent visits for repairs. Therefore, they advised me to opt for coil overs instead.
59 minutes ago, steve2006 said:
It looks a very clean well looked after example with no rust on the doors or window delaminating. Have you had the wheels refurbished as they look very good too.
Yes, it looks great even after 20+ years.  Nope, I haven't refurbished the wheels(may be previous owner did it!)
I read somewhere that the cost of one suspension strut was in four figures, and that there are no aftermarket suppliers. The car was sagging at one corner, and I knew the strut had failed. At 20 years old, the other three struts had a limited life expectancy. My insurers valued my car at £1100 at the time, so converting to coil springs and shock absorbers  was a no-brainer for me. I used Toyota and KYB components and my insurers did not consider it to be a modification. A good result all round.
