Clutch & Flywheel
simonskippy
I am looking for a new clutch and Flywheel too. The only flywheel I have found is JUN.
If I change the flywheel, will that make the reves more responsive? I.E At the moment, when I rev the car, the revs move slow up, and slow going back down..
If the flywheel is a lightweight one (like the JUN) then yes the engine will feel more responsive.
Is that the same as a thrust bearing?
MWAF :ph34r:
A thrust bearing is a type or bearing that can be used for many applications.
But I guess when talking about a clutch - a clutch release bearing, throw out bearing or thrust bearing are all names for the same thing.
  • 2 months later...
Alex...what happened to this Group buy....did I miss it?? I would be interested if it was started up again!
Can you update us with a new price for each covering, shipping, duty...etc etc.
Thanks - Neil
Does anyone know where (south UK) and how much it would be to get a lightweight Flywheel, clutch release bearing and gearbox input shaft bearing bought and fitted
I def want to get a new Flywheel, and would like the bearings checked/replaced as required.
