Some GS questions if you don't mind
I test drove a 2013 GS450h LUXURY today and was really impressed by the refinement and speed of the car.
However.. I found the mouse interface a nightmare, whilst driving it and meant I had my eyes off the road alot.
Even when parked up I was struggling to control it and get it to go where I wanted it. Just carrying out a simple action was difficult.
Has anyone else struggled with this, or managed to overcome initial difficulties?
Is it the same system in the RX450h?
God I miss buttons.
Also, don't these any of these high-end cars come with privacy glass, head up display or LED headlights?
I also found the headrests angled too far forward and made my neck ache. I have the same problem with modern Hondas and Volvos.
Does anyone know if there is any solution to this?
Thanks for any replies
James,
Others will answer your first three queries but I agree about the headrest. I had a loan GS300h whilst my car was in for service and I had to remove the headrest to be able to drive. I mentioned it to the salesman when I retuned the car but he seemed not to get the point. He was not a tall person though so perhaps it was OK for him.
I have the same problem with several of the new range. My Mk2 and Mk3 GSs were fine. The Mk4 is so bad that I would not buy one.
Does the headrest in the Mk 450h move automatically according to the seat settings? The Mk3 does but I have not seen this mention in Lexus literature.
John
25 minutes ago, OldTrout said:
James,
John
No the headrests do not move automatically with the seat settings, well they didn't on my MK4 450h f sport, iam sure they didn't on the MK 3 either
My mk3 drivers headrest moves up/down with the seat forward/backwards movements.
There's an almost hidden button on top of the seat to adjust the headrest.
I've not found the headrest front/back position to be an issue but maybe I slouch too much, or I's jus' chillin' :wacko:
God I miss buttons.
With regard to the mouse to control the infotainment, the sensitivity can be adjusted to make it easier to use. Additionally, its something that you have to get used to over time. Its not a case of just getting in and using it once. It requires a bit of practice.
All Lexus vehicles post 2012 now use the remote touch interface, either through the physical mouse or a touchpad. The only exception are vehicles without premium navigation which use a rotary controller.
I believe privacy glass wasn't an option on the GS or fitted as standard. LED headlights weren't available on the pre-facelift GS. They became standard across the range when the facelift came out, either in single LED or Triple-LED format depending on trim level. I know that HUD was available in the States, but I dont think it was available in the UK on the GS bar the GS-F and on the Facelift GS Premier
Not too sure on the headrest. I would assume you don't have the seat adjusted correctly. Again, in most cars, this is usually something that takes time to figure out
If you can stretch to Premier spec, the 18-way seats offer a greater range of adjustments, including fore/aft adjustment of the top quarter of the seat which would resolve the headrest issues. The headrests are also nicely cushioned and have aeroplane-style wings you can pull out if you fancy a snooze in the outside lane.
Regarding privacy glass, the rear windows also get blinds all round on the Premier - not quite the same thing but they do the same job.
The HUD came pre-facelift with the 300h Premier but only post-facelift on the 450h Premier.
The mouse interface is truly a terrible thing, but you do get used to it. I prefer it with the fake resistance turned all the way down, as that makes it seem less like it's fighting you all the time. The main issue isn't so much with the hardware, it's that the interface ergonomics were very clearly intended for a touch screen, meaning you're constantly trying to fly the cursor all around the screen to hit the relevant 'buttons'. It's never going to be pleasant to use, but muscle-memory does kick in after a while and it becomes less of an aggravation.
On 6/13/2018 at 10:53 PM, Hangie said:
LED headlight (low and high) were available since 2012 as an option.
I'm not sure if that's true. No pre facelift 4th gen GS has had LED lights fitted to it that I know of. It's not in the brochure either
http://media.lexus.co.uk/2012/02/all-new-lexus-gs-from-32995/
This press release from 15/02/2012 states LED headlampss were an option on the premier spec.
Hmm yep it does. I wonder how many cars were actually optioned with it though. Not many I don't think if any at all
In UK it was rare addition indeed. I know at least one with it - mine 🙂
In my opinion it is 1k well spend especially if you are driving a lot at night.
Mine wasn't!
