Dudes,
Can you come to my rescue.
My heater works fine in the morning for the first 30 mins or so. Nice and warm blowing out all vents. Then after 30 mins starts blowing cold!! Any ideas. I had a new heater control/clock installed about a year ago so i`m at a loss as what is causing this.
Cheers Dudes :driving:
I have the same problem, if you turn the heater control up 3-4 degrees does yours come back, mine does?
I dont think the new clock/temp would have any effect because they only report what the system is telling them, also had mine replaced and its made no difference
I'm beginning to think that mine maybe the temp sensor wherever that may be, (if anyone knows where it is, can they let me know please) but as I dont do that many long journeys, it doesnt cause me much of a problem
Dave.
do u have climate control on that model of LS? if so there will be a small grill somewhere around the dash area - the sensor will be there, as air is drawn in you might find that dust and dirt has accumulated on the temp sensor. that might be the prob????
Dude,
yeah, if I turn it up a couple of degrees it does come back but not for very long!
I will look for a sensor and let you know how I get on (Fluff).
Does the Temp/clock display have any diagnostic checks that a Simpleton like me can do!!!
Cheers guys :P
To check the aircon system, turn on the ignition while pressing the AUTO button and the REC [recirculate] button simultaneously.
After the indicator light check the diagnostic code check starts automatically
00 is normal
11 is open circuit or short in the room temp.sensor circuit
12 is same for ambient temp
THERE ARE 11 CODES
Press the OFF button to cancel the test.
To clear the stored code remove the DOME fuse for 10 secs. or more[under bonnet] B)
00 is normal
THERE ARE 11 CODES
I am having a similar problem. What are the other 8 codes? I perform the Aircon check above and seem to get codes of 14 and 15.
Hi!
This is the info from a series 2 ls 400 w/shop manual.
There is no code listed with the number 15
Code 14 is open circuit or short in the water temp.sensor circuit
code 13 open or short in evaporator temp.sensor circuit
code 21 same in the solar sensor circuit*
code 22 same compressor lock sensor circuit*
code 31 same in air mix damper position sensor circuit
code 32 same in air inlet damper position sensor circuit
code 33 open circuit in air mix damper sensor circuit
open or short in air mix servomotor circuit
air mix sevomotor locked
code 34 open in air inlet damper position sensor circuit
open or short in air inlet servomotor circuit
air inlet servomotor locked
*Open circuit in solar sensor and locking of the compressor are detected only when
they are current troubles.Other codes detect both current troble[buzzer sound]and
past trouble[no buzzer sound] ;)
  • 2 years later...
Gents,
I was trawling through the posts about heating problems and found this thread.
Has anyone fixed their problem buy sorting the codes?
I have a heater problem where the heaters just about get hot then go cool again unless the car is given some beans and then the heaters get hot again for a while.
I also have a bled out lcd so I'm assuming that's where you can see the codes - so if I di the test I can't see them.
What's the dome fuse look like and where's it located, may pull it out anyway and try to clean the sensors if I can find them.
Thanks,
Alex JB.
  • 6 years later...
I have a problem, if anyone has any ideas. Just bought 2005 LS430. Great Car. The temp control on driver's side of centre console is the problem. If I set it at "cold" then cold air blows from everywhere, but as soon as I change it to 16 deg or above it just blows hot air, with no apparent regulation. The temperature I set it to doesn't seem to matter. It just keeps on blowing hot air until I have to open a window or turn back to "cold"
Anyone else experienced this and any suggestions would be most welcome
Trevor
There have been cases where the servo motors have failed and caused these problems or the flaps have jammed or broken off.
The system consists of piping and then various control flaps that control the airflow to different parts of the car as required ( windscreen/feet etc ) and then another flap which controls the warm air/cold air mixing to provide the correct requested temperature.
Not sure how you would go about testing these but perhaps try turning the temperature from cold/hot/cold and listen carefully under the dash for any flap movements.
I would imagine Lexus could also diagnose this with their equipment at a price :(
Thanks Steve.
If it is quiet then when changing from cold/hot/cold you can hear a flap (or something) move. Certainly the air warms up instantly and cools down equally quickly..
It just that changing the temperature setting has no effect. I can either have full cold or full hot air.
Will probably take the route through the Lexus engineer and let you know the result
Thanks Again
Trevor
Thanks again Steve, and everyone with ideas on this forum.
I used the self diagnosis technique shown on some of these pages and it suggested a fault No 11 (which is either an open or short circuit on the room temperature sensor)
I removed the sensor cover to find a loose connection, which when repaired seems to have solved the problem, at a cost of £0
I am one very happy bunny
So many thanks to everyone on this and the USA forum without whom this would not have possible
Trevor
Another heater hiccup here. A Mk4 and the heater has an intermittent issue, where it will sometimes not supply any heating to the air being blown into the cabin. Then, it will come back OK. On some journeys it's fine, others it's not.
In combination with the Front button being used to keep the windscreen demisted, this results in a VERY cold car. :-o
I will try the diagnistic trick above (although I think that's for a Mk3 with a different control layout?)
One other thing to mention (saw it mentioned on another heater thread here): occasionally I hear a water 'sloshing' sound from somewhere in/under the dashboard when accelerating. I had initially thought that this was perhaps rainwater collecting in a void in the bodywork and that I should check it out, but now I wonder if the sound is from the heater unit/pipes and the sloshing sound indicates the presence of air? Which could mean an intermittent air lock stopping the heater from getting a supply of hot water...
  • 3 years later...
Just bumping up this old thread as I'm having the same symptoms as goldtop re: cool air being pumped out by the climate control on a Mk4. Did cleaning the cabin temperature sensor under the steering wheel resolve it for you?
The sloshing sound is probably condensed water from the refrigeration, but it should run out of the condensate drains before it ever gets to sloshing volume, so check that the system drains (including rainwater drains) are clear.
