What the add for that car lacks >if I were looking for one< is that there is no mention of how many owners & no mention at all of services or service history, the later being of utmost importance, although the mileage is low so thats good.
34 minutes ago, cruisermark said:
very nice car - im sure we have a member from isle of sheppey here?
me, but I've not seen it  ...  the car only made a visit here before getting scared-off and returning to somewhere more normal .............  hahahahaha
It's not cheap methinks  ................but just ok .........and now at a rarity price maybe for one that sounds and seems so good
That sounds a very good car at a reasonable price. You will be extremely lucky to find a "perfect" LS 400 but that one ticks quite a few boxes. I would be very surprised if it does not have a service history - if not beware. It is the same colour as mine, one of the BEST colour combinations IMHO. The gold colour (champagne) never shows the dirt and can hide the odd blemish. If I was looking for a MkIV LS 400 that would be worth a journey.
...  I think I remember getting @32mpg once many years ago, fully loaded on the motorway on cruise control at 80mph .............  never manage it otherwise but then that wasn't in a Mk4
Check its MOT history out. Loads of advisories, some fails. This car has sat around alot its only done 30K in the last 10 years. The seller was also selling a Porsche last Dec using the same excuse that he now has two dogs. Hes keeping the number plate. Approach with caution.
hahahahaha, the Isle of Sheppey is quite tiny  ......  and upgrade  ???  ...................  I think my Mk3 could be with me till the end of time tbh ......  or until it's a write-off or summat else dreadful befalls me....  but i must admit that the Mk4 would be a natural progression from my Mk1 and Mk2, both of which had premature fatalities
I was expecting that lol
How? I just checked DVLA with the number & this is what comes up:
"No vehicle that matched the data you entered could be found."-
ISLE OF SHEPPEY: What's the IOS got to do with anything, he said he drove the car from his home to the IOS and back home :confused: The cars is based in Silverstone, Northamptonshire isn't it?
OWNERS: The add says 4 owners plus the seller.
Pay attention folks. :lol:
Oh yes I see that now, also noted his reason for sale, dogs, I got this LS in 2011 & until last sept 23rd it had dome 50k running this dog around from London to her excercise areas,
I'll just update the DVLA MOT check, I just typed in my own number & below is what DVLA said abot that/it:
" Vehicle details could not be found as it has not been possible to locate the vehicle details, your enquiry cannot proceed and has been cancelled. If you want to check the vehicle record held by DVLA"
Its like Credit Card details you mustn't leave a gap between the letters and numbers
Registration number: W4FTR
  • Vehicle make LEXUS
  • Vehicle model LS400
  • Date first used 29 June 2000
  • Fuel type Petrol
  • Colour Bronze
MOT history of this vehicle
  • Test date 22 February 2017
  • Expiry date 21 February 2018
  • Test Result Pass
  • Odometer reading 129,122 miles
  • MOT test number 5811 5487 1422
  • Advisory notice item(s)
    nearside front lower Suspension arm has slight play in a ball joint (2.4.G.2)
    offside front lower Suspension arm has slight play in a ball joint (2.4.G.2)
    offside rear Brake pipe slightly corroded (3.6.B.2c)
    central Exhaust has a minor leak of exhaust gases (7.1.2)
    rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
    rear Brake pad(s) wearing thin (3.5.1g)
  • Test date 18 February 2016
  • Expiry date 17 February 2017
  • Test Result Pass
  • Odometer reading 117,684 miles
  • MOT test number 1124 4452 1235
  • Test Result Fail
  • MOT test number 7088 9966 2364
  • Reason(s) for failure
    Exhaust emissions Lambda reading after 2nd fast idle outside specified limits (7.3.D.3)
  • Test date 12 May 2015
  • Expiry date 8 June 2016
  • Test Result Pass
  • Odometer reading 116,438 miles
  • MOT test number 9488 1273 5117
    Rear Sub-frame corroded but not seriously weakened (2.4.G.1)
    Rear Subframe mounting prescribed area is corroded but not considered excessive (2.4.A.3)
    Nearside Rear Suspension arm corroded but not seriously weakened (2.4.G.1)
    plastic trims shields and guards covering some perscribed areas
    exhaust sytem corroded and repaired
  • Test date 9 May 2014
  • Expiry date 8 June 2015
  • Test Result Pass
  • Odometer reading 115,350 miles
  • MOT test number 5082 6952 4177
    Nearside Rear Subframe mounting prescribed area is corroded but not considered excessive (2.4.A.3)
    Rear Anti-roll bar linkage ball joint dust cover deteriorated, but preventing the ingress of dirt (2.4.G.2)
    exhuast system corroded and repaired
    front and rear floors and chassis rails corroded
  • Test Result Fail
  • MOT test number 3897 9942 4117
    Exhaust has a major leak of exhaust gases (7.1.2)
  • Test date 9 May 2013
  • Expiry date 8 June 2014
  • Test Result Pass
  • Odometer reading 114,152 miles
  • MOT test number 2260 9902 3441
    Brakes imbalanced requirements only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.5b)
    sill covers fitteed
    many rear suspension components are corroded
    front tyres cracking
  • Test date 15 May 2012
  • Expiry date 8 June 2013
  • Test Result Pass
  • Odometer reading 113,133 miles
  • MOT test number 9786 5673 2115
    Nearside Rear Brake pipe slightly corroded (3.6.B.2c)
    sill covers fitted
  • Test date 9 May 2011
  • Expiry date 8 June 2012
  • Test Result Pass
  • Odometer reading 111,621 miles
  • MOT test number 6356 4932 1117
    Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
    engine shields and sill covers fitted
  • Test Result Fail
  • MOT test number 2675 8982 1136
    Nearside Front position lamp(s) not working (1.1.A.3b)
  • Test date 11 May 2010
  • Expiry date 8 June 2011
  • Test Result Pass
  • Odometer reading 110,540 miles
  • MOT test number 9127 0163 0106
    sill covers fitted
    plastic trims shields and guards covering some persacribed areeas
  • Test date 11 May 2009
  • Expiry date 8 June 2010
  • Test Result Pass
  • Odometer reading 109,290 miles
  • MOT test number 3608 2193 9139
    Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
    sill covers fitted
  • Test date 15 May 2008
  • Expiry date 8 June 2009
  • Test Result Pass
  • Odometer reading 107,795 miles
  • MOT test number 4737 3693 8174
    Nearside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
    Nearside Front Tyre worn close to the legal limit (4.1.E.1)
    sill covers fitted
  • Test date 31 May 2007
  • Expiry date 8 June 2008
  • Test Result Pass
  • Odometer reading 105,084 miles
  • MOT test number 4703 5155 7168
  • Test date 22 May 2006
  • Expiry date 8 June 2007
  • Test Result Pass
  • Odometer reading 100,977 miles
  • MOT test number 9628 0264 6195
    Nearside Tyre worn close to the legal limit (4.1.E.1)
    Nearside Rear Rear wheel bearing has slight play (2.6.2)
    Offside Rear Rear wheel bearing has slight play (2.6.2)
    Exhaust has part of the system slightly deteriorated (7.1.1a)
    engine shields fitted
